Rule Packages!
11014
10
11-08-2013 10:37 PM
aminsediqfar
Hi there!
What is exactly rpk file? (i mean rule packages) and how can be created it?
Thanks.
MatthiasBuehler1
Hi ..
In the CGA code, do you have a Start Rule annotation ?
E.g.
@StartRule MyRule -->     Hello.
To create a RPK, you must have 1 ( exactly 1 ) '@StartRule' annotation.
MatthiasBuehler1
hi,
'rule packages' are packaged rules that include the assets.
note that rule packages by default contain only binary (compiled) 'CGB' rules, but the CGA rules can of course added.
you need CityEngine 2013 to create those RPKs. CE 2013 should be released soon!
m.
AnnaDang
Hi Matt,
Just curious, how do you open a rule package and use it in CityEngine? I managed to download baselayer.zip containing the portland example with some rules as cga and some as rpk. I want to see how the rules are created.
Anna
MatthiasBuehler
Hey Anna,
RPKs are basically zipped rule files including assets.
.rpk is actually a 7-zip file, so what you downloaded is a kind of zipped zip file.
If you have the .rpk file, you can use it directly in CityEngine and assign it to a shape.
If you want to look into the .rpk file, you can extract the contents as from a standard zip file. But it may be the case that the CGA code in text is not available in the rpk. It can be that only the CGB file is in there, which is a binary file that you can't open and look at.
Please let me know if there's more questions.
Matt
GucluSen
Hi Matt,
I try to export a cga rule file as rule package (.rpk file).
I can not share or create ".rpk", CE gives this warning:
[ATTACH=CONFIG]30101[/ATTACH]
I have read this article;
http://cehelp.esri.com/help/index.jsp?topic=/com.procedural.cityengine.help/html/manual/cga/rule_pac...
It's look like very easy but I cannot create a .rpk file. What is the meaning of "No start rule found"? Rule is active in my project and covered my buildings.
What shall I do?
Güçlü
MatthiasBuehler1
Hi ..
E.g.
GucluSen
I tried to use "@StartRule" definition and I have created my rule package.
Thanks 🙂
MatthiasBuehler
Congrats that it works for you!
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
[email protected]
www.garsdaledesign.co.uk
by Anonymous User
Not applicable
matt, did you just reply to a 1 year old post?
MatthiasBuehler
I got a reminder by GeoNet about a new post .. so it's fair to assume it's a current post.......
