Read data from a file
5454
18
03-16-2012 09:18 AM
CharalamposApostolou
Is there a way to read data from a file? I have a document file with some attributes in each line and i want to read some attributes and build objects according to that.
I know only the basics of Python. I set the buildingID to float like you told me.
MatthiasBuehler1
it works fine here ..
the try commenting out some things and print the type of buildingID :
buildingID = int (ce.getAttribute(shape, 'buildingID'))
print type(buildingID)
I am not sure if this is really the issue.
what version of CityEngine are you using ?
I am using the 2010.3 version
MatthiasBuehler1
for me it's working too, in 2010.3, without edits.
are you using all forward slashes in the file paths ? ( '/')
sorry, but it seems you really have to track it down line by line.. it works fine here, so it must something small.
maybe add a screenshot, where I can see ALL the details too, ok ?
[ATTACH=CONFIG]14972[/ATTACH]
ok i will try to find whats going on
I think am doing something wrong in the second argument of this:
buildingID = int(ce.getAttribute(Shape, 'buildingID'))
did i have to set a path like "/CityEngine/..../buildingID" ?
MatthiasBuehler1
hi ..
no, the attribute is just an object attribute, thus it needs no path. it's linked to the shape.
name correct ? no syntax error ? no space at the end or similar ?
did you select the shape while running the script ? if the selection is empty, nothing is done ..
Thank you very much for your help. the code worked perfectly. I hadto change something in the directory.
MatthiasBuehler1
shaaring, shaaring ! 😉
glad I was able to help !
