Rand
5241
10
11-30-2016 01:57 AM
PmssS
CityEngine 2015
is it possible to use 'rand' to randomize only two values, such as:
attr lenght = rand (6 - 12)
the use of "," will give me all the numbers between those two. That is not what I want.
I test this and it worked for a Block (Parameters = No subdivision and Uneven) and I tried again for another block with the same parameters and did not work.
is there an alternative?
cheers
Pedro
LR
Ah! When you split it with CGA it's still one shape, so it only has one extrudeFactor. I thought you did Shapes --> Subdivide.
Put this
set(extrudeFactor, 20% : rand(1,3)
 20% : rand (3,5)
 20% : rand (2,4)
 20% : rand (1,2)
 20% : rand (3,4)
 else: 1)
above your
extrude (floor(extrudeFactor)*Height)
and change
extrudeFactor to attr. You can tag it with @Hidden so it doesn't show up in the inspector.
