rand height & color for containers
3160
6
08-01-2016 06:25 AM
PmssS
Dear all,
I am drawing a storage area.
and at the moment i am struggling with the containers.
Those are an imported shapefile. The containers have always the same height = 2.6.
The goal is to randomize several heights (multiples of 2.6 to a maximum of 10.4 = 4 containers over each other).
and colors.
This is my failed attempt. I'am sure is simpler than this. I just probably went in the wrong direction.
@StartRule
attr A= 2.6
attr B= 5.2
attr C= 7.6
attr D= 10.4
Containers-->
               extrude (rand(2.6, 2.6), rand (5.2,5.2), rand(7.6,7.6), rand(10.4,10.4)) HGT
HGT-->
               case HGT == A: ContainerColor
               else:
                         case HGT== B:
                                   split(y) {'0.5 : ContainerColor | ~0.5: ContainerColor}
                         case HGT==C:
                                   split(y) {'0.33 : ContainerColor | '0.33 : ContainerColor | ~0.33: ContainerColor}
                         else:
                                   split(y) {'0.25 : ContainerColor | '0.25 : ContainerColor | '0.25 : ContainerColor | ~0.25: ContainerColor}
ContainerColor-->
               color(rand(0,1), rand(0,1))
Tags (3)
LR
Try this..
attr containerHeight = 2.6
@StartRule
Lot -->
  extrude(floor(rand(1,5))*containerHeight)
  print("Height: " +scope.sy +"\nContainers: " +scope.sy/containerHeight +"\n---") #print for control
  split(y){containerHeight: ColorContainer}* #optional split
ColorContainer -->
  color(rand,rand,rand)
PmssS
getting there with this but not yet accomplished:
attr cont_ht     =2.6
attr total_ht      = 10.4
lot -->
          extrude (total_ht) Container
Container -->
          split(y) {cont_ht : ContainerColor | cont_ht: ContainerColor}
ContainerColor-->
LR
Try this..
@StartRule
Lot -->
ColorContainer -->
PmssS
Thanks!!
although it looks easy it would take me ages to get that!!!
cheers
Pedro
PmssS
Hello Hello,
indeed it worked. But i have more than 1700 objects that use this rule... and the the performance of the resulting webscene has been reduced drastically with the inclusion of those.
I have seen webscenes of cities with much more objects than I have. and those are working very well.
How can I improve the performance of the webscene.
cheers
Pedro
LR
It's usually the amount of faces/polygons what makes a scene choke. If you look closely, those large scenes generally consist of just simple textured blocks, so more or less building_number*6 polygons. However you're splitting (ergo multiplying) your polygon count. Maybe it would be better to skip the split and visualize it with a series of textures instead.
PmssS
Well indeed that is the problem! Sadly I needed to reduce the detail of the objects, this is the new rule in case someone will have the same problem:
I still don't understand how these cities of the wizard_cities or ESRI lib, perform so well... they have much more data than mine.
@StartRule
Lot -->
