Python consol error: "Failed to read servers response: Connection refused: connect"
1873
09-09-2016 04:38 PM
PeterCharles
What exactly does this mean when executing script in the python consol?
Is it referring to geometry not being properly connected and therefore called?
Im not totally new to python, but I am within the city-engine environment
Any hints most welcome. Thanks.
DanPatterson_Retired
sounds you aren't working with data that is stored locally... assuming python is
ThomasFuchs
Hello Peter
Generally Python 2.7 coming with CityEngine does support network connections.
Scripts can have access to CityEngine functionally via Python Scripting
The error message seems to come from the Python script you are using that is trying to make a connection to a server.
For help on these topics I usually search Overview — Python 2.7.12 documentation or Stack Overflow.
