Proxy settings CE 2019.1
1197
11-13-2019 07:44 PM
by Anonymous User
Not applicable
I'm trying to configure CE for our corporate proxy. The company has an auto detect proxy config setup in IE. I can get the settings by entering http://tpproxypac.xyz.co.nz/wpad.dat (or http://wpad/wpad.dat in Chrome) into IE, which then downloads a wpad.dat file with the various proxy details. When I put that link into CE's proxy settings I get the following which doesn't work
I then completely removed the Proxy Script (PAC) config and entered it manually:
That fails too...and the odd thing is when I come back into CE, after closing and opening it, the new proxy settings are greyed out and it has the initial Proxy Script (PAC) setting active:
In the logs there's the following:
!ENTRY org.corebounce.rcp 4 0 2019-11-15 09:01:17.103
!MESSAGE Unable to load PAC 'http://127.0.0.1:45152/' - [Thread-14]
!STACK 0
java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:242)
at sun.net.www.http.HttpClient.New(HttpClient.java:339)
at sun.net.www.http.HttpClient.New(HttpClient.java:357)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1220)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1199)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1050)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:984)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at org.corebounce.net.PACParser.downloadPacContent(Unknown Source)
at org.corebounce.net.PACParser.getPacJS(Unknown Source)
at org.corebounce.net.PACParser.evaluate(Unknown Source)
at org.corebounce.net.PACSelector.findProxy(Unknown Source)
at org.corebounce.net.PACSelector.select(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1150)
at java.net.URL.openStream(URL.java:1045)
at com.procedural.cityengine.UpdateCheck.run(Unknown Source)
at java.lang.Thread.run(Thread.java:748)
!ENTRY org.corebounce.rcp 4 0 2019-11-15 09:01:17.105
!MESSAGE PAC error. Check proxy preferences. - [Thread-14]
!STACK 0
Any ideas?
Esri Technical Support
