problems after changing project location
3179
6
11-03-2013 11:56 PM
by Anonymous User
Not applicable
Original User: Infranavigator
Hi all,
I'm encountering problems in Cityengine after I changed my projectlocation by exporting en importing my project. In my project there is a folder with some static models (.dae). If I try to drag a model from this folder into my viewport I get the import window. The folder and models are already imported. How can I fix this? I tried removing the folder with the models and import it again but that won't do anything.
Any ideas?
Best regards,
Patrick
MatthiasBuehler1
It's a trap !
http://www.youtube.com/watch?v=piVnArp9ZE0
imports levels:
Workspace level :
import project into workspace
Project level :
import data into project, e.g. terrain images, assets, GDBs, ..
Scene level :
import data in scene ( cej file = viewport )
You see that workspace and project level are almost indistinguishable.
Importing data into the scene via drag-n-drop (opens the import dialog) basically copies the data into the cej, so you can see it in the viewport afterwards.
A bit misleading, we know.. :eek:
Did this help ?
m.
by Anonymous User
Not applicable
Hi Matthias!
Admiral Ackbar is always spot on!
The data is already imported in the project. But when I drag it into my viewport I get "the import recources from the local file system into an existing project" dialog screen. I can repeat this proces over and over but I won't get the models into my viewport.
Patrick
MatthiasBuehler1
ah, that issue.
seems a dialog issue.
I've seen this too, yes.
instead of drag-n-drop, try:
right mouse click on the data to import, then 'import ...'
we've fixed some stuff in this regard for CE 2013.
matt
by Anonymous User
Not applicable
Original User: Haiyang.Xu
ah, that issue.
matt
I want to know when will CityEngine 2013 released?
MatthiasBuehler1
I cannot give you a statement on this, sorry.
We're working hard. 🙂
m.
by Anonymous User
Not applicable
ah, that issue.
matt
Hmm, tried this way, even exporting and importing only a few .dae models. It all doesn´t work. Maybe it has something to do with moving the project to a different location. I will try to bring the project to it´s original file location, maybe that´ll help.
p.s. Why don´t you skip Cityengine 2013 and name it Cityengine 2014, since the year is almost over... 😉
