pls pls way to set block type with python
2037
6
08-24-2022 09:44 AM
JeoCho
hi  friends
i need help ~
pls pls pls
i would like to set  block type.
i tried this way
 ce.setAttribute(block,'/ce/block/SKELETON',2)
ce.setAttribute(block,'/ce/block/RECURSIVE',0)
but not working .
how can i set block type with python ?
2 Solutions
JonasObertuefer
Hi @JeoCho,
The attribute is "/ce/block/type"
And the possible values are:
"Skeleton Subdivision", "Recursive Subdivision", ... (Same as in the inspector)
If the attribute is not shown as bold in the inspector you need to not only set the value of the attribute you also need to set the source of the attribute to user.
Here is an example, I adapted it from the python docs to match your case
block = ce.getObjectsFrom(ce.selection)[0]
ce.setAttribute(block,"/ce/block/type", "Offset Subdivision")
ce.setAttributeSource(block,"/ce/block/type", "USER")
Hope this helps!
Best,
Jonas
JonasObertuefer
Hi again,
Sure this is also possible. You just need to change your filter from ce.isgeneratedModel (this is no valid filter!) to ce.isModel. And then select it using ce.setSelection()
# all generated models in scene
models = ce.getObjectsFrom(ce.scene, ce.isModel)
ce.setSelection (models)
Shapes which have a rule file assigned but aren't generated won't be included in the ce.isModel filter.
cheers
Jonas
JonasObertuefer
Hi @JeoCho,
Hope this helps!
Best,
Jonas
JeoCho
Wow wow
Really thank you , really thank you
Sorry , can i question one more ?
models = ce.getObjectsFrom(ce.scene , ce.isgeneratedModel)
I generate model in a certain block
And i would like to select genrated model only
Like this
Is that possible ?
Sorry many ask
JonasObertuefer
Hi again,
cheers
Jonas
JeoCho
really really thank thank thank you for  answering
i made this script
but error,
really really sorry  , pls can you check this 2 script
1. this is script to select   ( select  generated model   in  selected block)
   but error
from scripting import *
ce = CE()
def selectblock() :
oneblock = ce.getObjectsFrom(ce.selection, ce.isBlock)
lots = ce.getObjectsFrom(oneblock[0] , ce.ismodel)
ce.setSelection(lots)
if __name__ == '__main__':
selectblock()
2  this is layer isolate script
 that is error also
ce = CE()
@noUIupdate
def main():
sele = ce.getObjectsFrom(ce.selection, ce.isLayer)
layers = ce.getObjectsFrom(ce.scene, ce.isLayer)
for layer in layers:
really  really sorry   sorry  for many ask
layer.setVisible(False)
if sele :
sele.setVisible(True)
main()
JonasObertuefer
Hi again,
First script:
  • There is a typo. instead of ce.ismodel you have write ce.isModel.
  • If you want to get the shapes of the block instead write ce.isShape
Second script:
Some general advice:
  • If you encounter errors check the message in the log, usually gives a good idea about what could be wrong
  • Use print statements to debug
Best,
Jonas
JeoCho
Thank you
Thank you.
thank you
