Per block OBJ export causes wrong textures
1779
03-22-2024 04:43 AM
EarnestWorthing
Dear community,
For my project I need to export each block individually to OBJ files. As a scene I use 'Generate an Imaginary City'. When I import the objects individually and import the OBJ file in blender I get dark textures which will also appear dark when rendering with blender.
This is not the case when I export the scene as a single OBJ. Here everything works perfectly fine.
Could you please help me further?
The following screenshot of a blender scene depicts the problem:
Dark building: OBJ export (Export models > OBJ > File Granularity: One file per start shape)
Lighted buildings: OBJ export (Export models > OBJ > File Granularity: One file as long as Memory Budget is not exceeded)
Further export settings:
EarnestWorthing_3-1711106975380.pngEarnestWorthing_4-1711107010477.pngEarnestWorthing_5-1711107088821.png
Normals appear correct (blue: outside, red: inside):
Thank you very much for your help in advance.
EarnestWorthing
Cause of the reported issue: transmission value of texture is set to 1 for individually exported objects
Quick fix: set value to 0
It might be helpful for users to have same values for both export versions.
EarnestWorthing
SimonHaegler
Thanks for reporting this!
Just to be sure I understand correctly: you manually fixed the Tr (or Tf?) value in the mtl files? Or did you set opacity in CGA?
Would you posting a diff of a "good" and "bad" mtl for your use case?
Best,
Simon
