Ortho Image does not align to DEM
3706
03-20-2014 08:59 AM
by Anonymous User
Not applicable
Original User: tmcbroome
I have a scene where the ortho images do not properly align. The image and data align just fine in ArcMap and ArcScene.
Projection:  NAD83 UTM Zone 18N (image, DEM, and Data are all using this projection)
I have tried images from different sources, a geotiff exported from ArcMap and the down sampled version of the original 30cm ortho image.
[ATTACH=CONFIG]32360[/ATTACH]
[ATTACH=CONFIG]32361[/ATTACH]
TimothyMcBroome
Has anyone else run into this issue?
by Anonymous User
Not applicable
Original User: natebrigmon
Have you tried clipping both the DEM and Ortho Image? The DEM doesn't look like it has all the terrain that the Ortho covers...
[ATTACH=CONFIG]32458[/ATTACH]
Maybe CE is getting confused? A matched image might perform better.
I would try a smaller matched dataset and then scale up if this continues as a real problem.
TimothyMcBroome
That is a good suggestion Nate, thank you. I will give it a go
