Orientate point to line
679
08-13-2013 02:25 AM
BenLeslie1
If I have a point feature that sits on a linestring is there some way I can rotate the point so it is orientated to the segment of the line upon which it sits?
i.e. so I can import gantry objects at known points over a railway or road without having to rotate them manually.
(actually, in an ideal world, if a point sits on a linestring vertex I would like it to be rotated half-way between the angle of the two segments either side of the point.)
Maybe this is a question for the python forum....?
MatthiasBuehler1
That can not be solved with CGA since CGA starts with a given shape. Shape-Shape interactions cannot be done with CGA.
Either, you'd have to use Python or preprocess the data in ArcGIS / FME.
Note that points have no orientation and that CE creates little rectangular shapes, which are oriented in XZ ( XY in GIS terminology ) coordinates - means along the world axes. So I'd recommend you work with all the rotation values preprocessed.
Let me know if you're an ArcGIS user or not. If not, I could help with Python.
Matt
