No textures on buildings from Get Map Data.
1000
10-28-2019 03:26 AM
ChrisKautz
Hi
win 10 CityEngine 2019
Importing from Get Map results in buildings with no texture after clicking the generate button. Was working before updating the library. Any help appreciated
DevinLavigne
Can you post a screen cap?
CherylLau
  • Are you using 2019.0 or 2019.1?
  • What is the rule file and start rule assigned to a building?  Does this rule exist in your workspace?
  • Click on a building.  In the Inspector, is the attribute Representation set to "realistic with facade textures"?  If it is set to "solid color", which is the default, then the buildings will not have a texture from an image but will rather be a single color.
  • What are your viewport settings?  Are textures enabled (shortcut keys 6 or 7)?
