I want to make a 3D circular culvert in the city engine using the Rule package. I made a solid 3d circular culvert but I want a hollow 3D circular culvert. So someone please help me to complete this task. How can I do this?
Hello @bhusalshishir
Here is CGA code that creates a primitiveDisk and then uses the offset operation to hollow it out.
Then the extrude operation gets applied on the annulus to form a culvert. Finally, the setNormals operation is used to set the normals of the inner and outer mantle to soft.
version "2024.1"
@Description("Inner diameter") @Distance @Range(min=0.1, max=5)
attr diameter = 1
@Description("Culvert length") @Distance @Range(min=0.1, max=20)
attr length = 2
@Description("Wall thickness") @Distance @Range(min=0.1, max=1)
attr thickness = 0.1
@Description("Number of subdivisions of the outer mantle")
attr sides = min(128,max(16,floor(8*diameter)*4))
@StartRule
Culvert --> Annulus
Annulus -->
primitiveDisk(sides, diameter+thickness)
offset(-thickness)
comp(f) { border = Extrude}
Extrude -->
extrude (length)
comp(f) { side = setNormals(soft) Culvert. | all : Culvert. }
version "2024.1"
attr diameter = 1
attr length = 2
@StartRule
Culvert --> Annulus
Annulus -->
offset(-thickness)
Extrude -->
extrude (length)
Thank you so @ThomasFuchs for your help, it means a lot to me. Thank you for your time and assistance.
