My Plint Area. Need Help.
2079
08-02-2012 10:10 PM
RamliJannatul_Alia
Hi all City Engine cga coder 🙂 ...
im trying to create a cga rule for plint area..
this is my idea..
1) i do setback (street) for a lot
Lot-->
setback(setBackRoad) {streetSide: Garten | remainder : Lot2 }
2) I try to split into 4 small lot...
Lot2-->
 split(x){ '0.5 : one |   '0.5 : two }
 split(v, uvSpace, 0) { 0.5 : three}
But it do not generate like i want
heres the pic [ATTACH=CONFIG]16625[/ATTACH]
its should split v..
how can i save the value of area Splitted in a attr? ive tried but failed...
basically in plint area i have to find remainder area after setbackroad has been applied and building are allowed to build in plint area only.. for example 25% of geometry.area...
MatthiasBuehler1
hi !
first, 3 things :
1] shape copies
if you write :
A -->
    B
    C
you get 2 copies of the incoming shape (A), named B and C which are identical. this is sometimes useful, but not in your case.
if you write :
Lot2-->
you basically first make 2 copies of Lot2. thus you get wrong geometry. what you want is to split 'one' and 'two' further in the opposite direction, so you either need to define a new rule for this or write the same operation in the same line. CGA, in this case, does not go down step by step through each line.
2]
familiarize yourself more with the scope here :
http://forums.arcgis.com/threads/44417-CGA-Understanding-the-concept-of-the-scope
and notice that for splitting in u and v directions, you first need to set the UVs properly first with setupProjection() and projectUV(). but in your case, you rather just want to split in x and z directions.
only Street and Sidewalk shapes have already properly layouted UVs so you can split them nicely. on Lot shapes, I'd never use UV splits.
3]
you can use the so-called 'generic attributes'
define an attr, e.g. :
attr remainingLotArea = 0
then, after the setback where you get the remainder shape, set the attr :
set(remainingLotArea, geometry.area)
after that, you can access this attr in the rest of your code.
hope this helps you further.
RamliJannatul_Alia
Mathias!! thanks for your reply. yup you were right actually what i need is to split in x and z direction... i didnt notice about z by using split(z) until you mention. here update of my splitting! thanks!!
[ATTACH=CONFIG]16671[/ATTACH]
the geometry.area attr you post here.. i ve used it! it works!! thanks... do you have any idea where can i get more tutorial on city engine T_______T. most of time i use the help ..
MatthiasBuehler1
there's tutorials with help HTML files you can download from within CE.
Help --> Download Tutorials and Examples
