Modify the Custom Coordinate System
1729
04-10-2024 02:02 AM
ChanningWang
Hello,
I'm currently trying to generate a city model from an OSM map, and I want the 3D model to align with my other geographic data. To achieve this, I've been using a projection file(.prj) to add a custom coordinate system.
However, I've noticed that if two projection files describe geographic locations that are very close together, CityEngine doesn't allow me to add a custom coordinate system. Therefore, I'd like to ask how I can delete a custom coordinate system that I've already added, or if there are other methods to address the issue I'm currently facing. Thank you.
ThomasFuchs
Hello @ChanningWang
Thanks for your question. Usually, it is not necessary to remove user coordinate systems. If you still want to do it, modify the CityEngine_User_Projections.xml configuration file. It resides in the <user>/AppData/Local/Temp/ Folder.
ThomasFuchs
Hello @ChanningWang
