Modelling buildings based on Building Coverage Ratio (BCR) and FAR values in CE
1480
12-04-2017 12:42 AM
JafarNajafli
Hi all,
I'm aware that similar questions have been asked before but none of the solutions have worked for me.
Basically I have to model my buildings based on the target Building Coverage Ratio, Setback Distances and FAR values given by the client. To do this I start with defining my setback distances which leaves me the footprint area. After this point I was able to figure out how to extrude my buildings based on FAR values although I cannot find a way of how to restrict the footprint area to a certain percentage of the parcel and also interconnect both the BCR and FAR values.
I attached a screenshot too that can be helpful to understand what I want to achieve.
Any input will be appreciated (:
 * File:    rule1.cga
 * Created: 30 Oct 2017 11:36:07 GMT
 * Author:  Jafar Najafli
@StartRule
attr Layer="PL_KONUT"
attr frontSetback = 3.5
attr backSetback = 3
attr sideSetback = 3
attr floorheight= 3
const parcelarea = geometry.area()
attr FAR = 1
attr BCR = 0.2
Parcel-->
case parcelarea > 1000:
NIL
else:
setback(frontSetback) {street.front: NIL | remainder :
setback (backSetback) {street.back: NIL | remainder:
setback (sideSetback) {street.side: NIL | remainder: footprint
footprint-->
extrude(world.up.flatTop, floorheight*(parcelarea/geometry.area()*FAR)) Building
report ("Height", scope.sy)
Building -->
report ("floorarea", geometry.area(bottom))
report ("FAR", geometry.area()/parcelarea)
report ("BCR", geometry.area(bottom) / parcelarea) ## this reports an accurate calculation of building coverage ratio, although it does not work as a modeling function
split(y){floorheight:zemin|{floorheight:arakat}*|floorheight:catikat}
comp(f){side:cephe}
AbhishekSobbana1
GFA & FAR Calculations with CityEngine - YouTube, I hope this tutorial will help you to figure out FAR.
Regards
Abhishek
JafarNajafli
thanks for the link @Abhishek, I am familiar with that tutorial and it has helped me to write my rule to extrude my buildings based on FAR.  But like I mentioned in my thread, my main issue here is restricting the Building Coverage Area
For example, I want my footprint area to cover only 50% of the whole parcel and then extrude my building from that footprint. Hope I was able to explain what I want to do (:
AbhishekSobbana1
My best guess is, you can try SplitArea function, lets say BCA is 0.5 (50% of ground cover)
splitArea(x) {(geometry.area*(1-BCA)) : GreenSpace | ~1 : Extrude_Building}
I hope this helps you.
Regards
Abhishek
AzemKURU
Hi Jafar,
Did you find a solution for your problem.
I have a similar project which I want to show possible 3D building with given FAR, BCR and setbacks.
If so, is it possible to share it.
Thanks in advance.
