Issues exporting to a file gbd
3223
04-15-2016 09:29 AM
deleted-user-OlpHy1NoMNug
I'm trying to export a street (graph) layer to a file GDB which works but when I import the multipatch back into the same scene, its location and scale are way off.  I've done this before without issue so I'm not understanding the problem.
It's almost as if the data is being exported using a different coordinate system and/or measurement unit than the scene.
Thoughts?
Scott
ThomasFuchs
Hello Scott,
Thank you for your report. Can you please give more detail on the version of CityEngine and the coordinate system you used for your scene?
Exporting a street network as multipatch should be no different to a export of any other geometry.
For graph networks there is also the option to export it to FGDB as a plolyline.
