Is it possible to expand the CE UI, or access its UI elements externally in a consistent way?
1630
04-28-2016 02:11 AM
LR
I'd like to use a GUI for some python scripts. Right now I'm using automation scripting to send commands to the pydev console to run imported scripts, which works somewhat. Unfortunately that requires changing the script every time I reopen CE because the Standard Widget Toolkit CE uses (?) assigns as far as I can see random IDs to the windows, meaning I can't use those for targeting - the windows unfortunately don't report any window title I could use either.
