Is exporting labels to datasmith possible?
2178
12-06-2023 06:53 AM
Stefan_Harding
I'm trying to export to Unreal engine while being able to identify specific textured sections of a shape, so that they can be replaced with higher resolution textures. I've tried using labels and other methods, but non of it gets exported. Is there a way to do this?
JonasObertuefer
Hi @Stefan_Harding,
Did you try the workflow described in this blog post, already?
https://community.esri.com/t5/arcgis-cityengine-documents/from-cityengine-to-unreal-engine-the-journ...
See under section Materials -> Material replacement
Best,
Jonas
JonasObertuefer
Hi @Stefan_Harding,
Best,
Jonas
Stefan_Harding
Thanks for the help
Stefan_Harding
I'm having trouble with this method were it keeps saying there a list of unexpected tokens despite none being there.
JonasObertuefer
hmm this looks like a copy paste issue to me. I don't get any unexpected token errors when I manually type in whats in your screenshot
Lot-->
	set(material.shader, "/Material_test/Content/Megascans/Surfaces/Brick_Wall_wmknbhe/MI_Brick_Wall_wmknbhe_2K.uasset")
Did you copy it directly from the blog post? I remember having the same issue in the past that when copying CGA snippets from the blog that sometimes it copies some hidden char, which can't be handled by the CGA compiler.
I suggest to try it with a new file and manually typing it in or copy to notepad first.
