Import .gdb error: "The data extend too large, reduce the extend of the data"
3853
12-24-2013 05:39 AM
by Anonymous User
Not applicable
Original User: gsenyurdusev
[ATTACH=CONFIG]30097[/ATTACH][ATTACH=CONFIG]30098[/ATTACH]
I try to import sample .gdb database in ESRI Geostatistical Analyst training data for 3D visualization.
I try to use "import .gdb" function but CE says "The data extend too large, reduce the extend of the data".
I converted the hillshade data as raster and try to import, CE gives same error. I changed "Selected Envelop" values /1000.
That way, The data has imported.
But other feature classes or whole .gdb data can not import.
What can I do to fix that error and import .gdb?
MatthiasBuehler1
What's the longest data diameter in meters ?
by Anonymous User
Not applicable
Original User: Alexinho008
I have got the same problem
