I find this syntax odd, why is this so?
1091
05-14-2012 10:22 AM
RobertHexter
I think the reason that sometimes it is hard to adapt to the cga script is due to oddities like this that don't appear to make sense to those coming from other languages.
Why is it that this type of thing is as it is?
Does not work
case area > 1200:
                innerRect
  alignScopeToGeometry(yUp,0,longest)
  80% :
   offset(-3)
   Building
  else:
   Building
 else:
  Ground
Works
case area > 1200:
  80% :
   innerRect
   offset(-3)
   Building
  else:
                        innerRect
   Building
 else:
  Ground
MatthiasBuehler1
it was designed to behave this way. 😮
there's advantages, there's disadvantages, but there went a lot of thought in this design.
MatthiasBuehler1
Hi ..
I've had an interesting discussion with one of the Developers and he gave me a little more insight.
so here's an additional note :
if you look in the manual under :    Manual > Rule Based Modeling > Writing Rules     ,you see that CGA distinguishes between '4 Rule Types'. Now the basic 'structure' of those rules must have correct syntax, otherwise they won't parse. depending on what you write in the rule body, different 'levels' ( term loosely translated ) are defined which each have to correspond to 1 of those 4 types.
Your specific example can actually be created by using ' push pop' which adds such a 'level' in which you have again a correct rule type.
Let me know if there's more questions ..
MyRule-->
 case geometry.area > 1200:
         innerRect
   80% :
    offset(-3)
    Building
   else:
    Building
 else:
  Ground
RobertHexter
Interesting thanks for the additional information and follow up!
