How to subdivide shapes(blocks) using CGA or python code?
2027
09-19-2022 06:44 AM
Vita_Vonanli
Hi, I'm curious about how to subdivide an input 2D initial shape using CCA rule or python script?
I''ve seen many solutions about using split or splitArea to complete this, but there is a problem: the initial shape is still ONE object and cannot report informations about every subdivided lots respectively.
That means, I want the splitted lots be independent and can be assigned CGA rules respectively,  I think that is the same as the Shapes-Subdivide function in CityEngine menu bar,  but can I get them using CGA?
Here are some pictures to illustrate——
What 'split' function gets:
(only the initial shape can be selected)
What I want:
(only one object is selected)
Very need your help! Thanks!
JonasObertuefer
Hi @Vita_Vonanli,
There is no Shapes-Subdivide functionality in CGA but you can apply it to a shape using python and then assign your rule onto the created shapes again by python or via ui.
For more information check the python docs:
Hope this helps!
Best,
Jonas
JonasObertuefer
Hi @Vita_Vonanli,
Hope this helps!
Best,
Jonas
Vita_Vonanli
Thanks a lot for your suggestion Jonas! Using Python script in CE is a little difficult for me but I will try my best!
