How to combine imported streets and imported shapefile in CityEngine?
3349
04-19-2016 01:36 PM
TianfangJiang
Hi guys,
I want to combine the imported osm streets and shapefile in CityEngine, but I have encountered two problems. Could you please help me solve this?
First I imported the osm street into CityEngine, after that I tried to delete the streets which can not be aligned to the terrain, but I can not delete them after selecting. The streets are just like the picture below,
The second problem is the shapes which I imported into CityEngine coincide with the imported streets. The picture below shows this problem. What should I do to deal with this problem, is there any function or CGA rule to handle this?
This is the shapefile which I imported into CityEngine.
This picture shows that the shapes coincide with the imported streets.
Thank you for your help!
JawadhHabeeb1
Convert Streets to shapes with the following  go to Graph > Convert to Static Shapes.
This converts models to Shapes.
and later Layer > Merge Layers to combine the required layers
Cheers
TianfangJiang
Hi Jawadh,
Thank you for your help. I have tried your method to convert the streets to static shapes. After that I did delete the streets below the height map. But I don't want the streets to be static model, because I want to edit the streets further. Do you have any other method to solve this problem?
Thanks.
