How do you convert a linear data (shapefile) into a tunnel in CityEngine?
2354
08-17-2016 06:13 PM
AKINOLAEKUNDAYO
Can someone help me with the cga code to convert a line into a tunnel in CityEngine?
LR
Here's a simple one I made. You could use some recursion to make smooth arcs, but I try to keep the poly count low. Only works on straight lines, unfortunately. Change the nodes to crossings.
version "2016.0"
attr shapeType =""
attr streetWidth = 0
attr sidewalkWidthLeft = 0
attr sidewalkWidthRight = 0
import EsriStreets: "/ESRI.lib/rules/Streets/Street_Modern_Standard.cga"
@StartRule
 Lot -->
 case shapeType == "Street": MakeTunnel EsriStreets.Street
 case shapeType == "Sidewalk": EsriStreets.Sidewalk
 else:NIL
MakeTunnel -->
 extrude(streetWidth/1.2)
 alignScopeToGeometry(zUp, any, world.lowest)
 s('1,streetWidth+sidewalkWidthLeft+sidewalkWidthRight+2,'1)
 t(0,-1*(sidewalkWidthLeft/2+sidewalkWidthRight/2+1),0)
 color(1,0,0)
 rotateScope(45,0,0)
 split(y){1: NIL | ~1: OuterSplit1 }
OuterSplit1 -->
 rotateScope(90,0,0)
 split(y){1: NIL | ~1: InnerSplit1}
InnerSplit1 -->
 color(0,1,0)
 rotateScope(-45,0,0)
 split(y){1: Wall | ~1: InnerSplit2}
InnerSplit2 -->
 color(0,1,0)
 rotateScope(90,0,0)
 split(y){1: Wall | ~1: InnerSplit3 | 1: Wall}
InnerSplit3 -->
 rotateScope(225,0,0)
 split(y){1: Wall | ~1: InnerSplit4 }
InnerSplit4 -->
 rotateScope(90,0,0)
 split(y){1: Wall | ~1: NIL }
Wall -->
 color("#BBBBBB")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
AKINOLAEKUNDAYO
LR, much appreciated. Apologies! Did not make myself clear enough. I was looking for a railway tunnel - cylindrical in nature.
LR
Here's a basic approach for a hollow cylinder - I insert a disc, move/extrude it and then delete the center. Again, straight lines only.
version "2016.0"
attr shapeType =""
attr TunnelLength = 0
@StartRule
 Lot -->
 else:NIL
MakeTunnel -->
 set(TunnelLength, scope.sx)
 primitiveDisk(20, 5)
 center(xyz)
 r(0,90,0)
 t(-scope.sx/2,0,-TunnelLength/2)
 extrude(TunnelLength)
 setback(1){all: TunnelColor | remainder: NIL}
TunnelColor -->
 color(1,1,0)
AKINOLAEKUNDAYO
Thanks Ivan,
Where have you been?
