how can I select the shapes with customized condition?
3750
09-11-2015 03:41 AM
jiazhiqiang
follow the title, e.g
                                   1. only want to select the shapes  with : model height > 10.
                                   2. select the shapes with parameter shapeCreation = true && area > 20 ...
                                    etc
newbie,need details. thanks in advance!
Tags (1)
DanPatterson_Retired
have you seen this?
http://desktop.arcgis.com/en/desktop/latest/map/working-with-layers/building-a-query-expression.htm
and if so, what quries have you tried?
of course this assumes you have necessary fields in the table
jiazhiqiang
sorry , Maybe I committed to the wrong place.this CE involved.
just delete this thread then
TimothyHales
Esri Notable Contributor
I have moved this discussion to CityEngine​.
