facade wizard mix
1373
05-21-2023 09:41 AM
BastianPallero
Hello, im new with the software but i made a test with the facade wizard with a simple house and it works really well, im here to ask about th cga file that export the facade wizard, Is it possible to make a mix between multiple cga files of houses, in order to get new combinations of rules to make a facade?
plfontes
Yes, it is possible.
There are different ways to do that. You can incorporate the code into a single CGA file and call the rules for the different facaded within the unified CGA file manually or randomly. Or you can import the file into a master facade rule that applies mannualy or randomly different facade CGA files to your models. See import—ArcGIS CityEngine Resources | Documentation
