Extrude shapefile according to height attribute
19609
13
02-29-2012 09:53 PM
CarlBester
I have imported a shapefile into CityEngin and need to extrude the buildings according to an existing height attribute in the shapefile. For example: If there are 3 buildings with height values of 30; 70; 20. Then the buildings have to be extruded according to each one's value.
Do I need to create an attribute which represents the height attribute for each specific shape? The height attribute is Building_height.
attr z = Building_height
Lot --> Shape extrude(z)
Do I need to define the shapefile in the rule code?
Any help will be greatly appreciated
LR
Convert it to float:
attr HEIGHT = ""
Lot -->
  extrude(float(HEIGHT))
If you want to use a slider to adjust the height afterwards you can do this:
@Hidden #optional
attr HEIGHT = ""
attr myHEIGHT = float(HEIGHT)
Lot -->
  extrude(myHEIGHT)
valeriisendetskyi
Thanx for reply.
But it doesn't want to take it either.
I've reloaded the rule, but nothing changed.
Would have been cool to convert attribute permanently. As a separate action. But I'm not good enough in CE to figure it ou
proof: Attribute Connection Editor
LR
You have to define it properly in the rule too, i. e. height ="", not height = 0, because then the rule assumes it's a float and won't connect to your str object attribute.
valeriisendetskyi
Thanx a lot! Now it works perfectly)
