Export errors ...
4695
04-01-2015 04:29 AM
ErwinVervacke
Hi, when exporting to obj or fbx I get the following error:
The batch export completed but at least one error occurred. See stack trace for detailed error information. - [main]
EXCEPTION STACK TRACE
com.esri.prt.clients.ce.CEClientException: Not all shapes are generated
  at com.esri.prt.clients.ce.GenerateSlice.runGenerate(Unknown Source)
  at com.esri.prt.clients.ce.GenerateSlice.run(Unknown Source)
  at org.corebounce.threads.RunnableContextJob.run(Unknown Source)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
SESSION DATA
eclipse.buildId=unknown
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_GB
Framework arguments:  -keyring /Users/Erwin/.ce_keyring -showlocation
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -data @noDefault -keyring /Users/Erwin/.ce_keyring -showlocation
Any idea what this means and what is 'wrong'?  I'm working on OS X Yosemite with CE 2014.1 Trial
Thx, Erwin
JawadhHabeeb1
Hello Erwin,
Some shapes may not have generated the models in which you are exporting.
Try this
- After the batch export error is shown close the export window and open Window > Show Problems.
- The show problems tab will show what all models were not generated along with its names.
- Then select those shapes where the models are not generated and regenerate them
hope it works
Regards,
Jawadh
