Error importing OBJ
3915
10-15-2014 06:53 AM
IonutAlixandroae
Hello,
I have a problem importing an OBJ Model exported from Maya.
I did the model in Maya and also textured it but when I want to import it in CE some of the textures are missing ( some colors appears instead), and also I can import the obj model only as static model.
Any settings that have to be done in Maya before exporting or any solution?
Thanks !
Tags (3)
by Anonymous User
Not applicable
Try Collada?
MatthiasBuehler
maybe the colors you see are those of the 'unknown texture' texture file that is assigned if a texture is not found.
check:
- are all textures in the same folder as the obj file and the mtl file
- the files are in typical formats ( e.g. tif, jpg, png, ..)
let me know..
Matt
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
[email protected]
www.garsdaledesign.co.uk
IonutAlixandroae
I think there was a problem with the .mtl file when exported from Maya..
Thanks !!
