Error import .dae models
2911
04-08-2014 07:15 AM
Te-MingChang
java.io.IOException: Asset reader failed! See error log.
at com.procedural.ceui.wizards.GeometryImportParams.compBoundingBoxAndCoordSys(Unknown Source)
at com.procedural.ceui.wizards.CEImportParams.getBoundingBoxAndCoordSys(Unknown Source)
at com.procedural.ceui.wizards.OffsetParams.getFinishState(Unknown Source)
at com.procedural.ceui.wizards.CELayerImportWizardPage.performFinish(Unknown Source)
at com.procedural.ceui.wizards.CELayerImportWizard.performFinish(Unknown Source)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.corebounce.rcp.CBDisplay.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$Import.executeHandler(WizardHandler.java:147)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.procedural.cityengine.release.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
MatthiasBuehler1
please post the asset too ..
Thanks.
Matt
Te-MingChang
Thanks.
Matt
Attached is the asset.
MatthiasBuehler1
Hi !
Please use CE2013. It works there.
If you have a 2012 license, you have access to 2013 anyway ..
Ok ?
Matt
Te-MingChang
Hi !
Ok ?
Matt
I'm using CE2013.1
MatthiasBuehler1
Okay,
So it works fine for me in 2013.
Then it must be something with your installation.
Please try:
- Create a new WorkSpace
- Delete the hidden '.cityengine' folder in the user account folder.
Hope this works ..
matt
