Creation of panels on complex geometry
509
10-10-2019 05:28 AM
AlexanderBraun
I am an archaeologist and work with visibility-analysis. So far I used to create models and used the "PanelizePolygon_uid.rpk" rulefile in CityEngine to create panels to then import them as a GDB to ArcScene.
However I tried to apply the rule to a simplyfied statue (282 faces, 284 vertices). The model is solid, no holes or something like that.
The rule sadly doesn't create the multipatch features needed for a visibility analysis in ArcScene.
Is there a new rulefile or a solution for the problem?
