Colorize the buildings and roofs from its attributes.
7121
17
03-24-2015 12:46 AM
RushikeshPadsala
Hi there. I have a gdb which contains, Multipatch LOD2 Buildings (in 3D), I have roof surfaces, trees, water and terrain. I want to colorize the Buildings and the roofs with the attributes stored inside it. For buildings, I want to colorize according to building type (Residential, Office etc). The field for landuse type is Land_Type. Similarly I want to color roofs, but all with the same color lets say light brown. Nothing needs to be extruded as everything is already in 3D. Please help me to write the rules, or any examples which has the similar rules. I am completely new to CityEngine. Please help. I use city engine 2014.1.
Thank You.
by Anonymous User
Not applicable
Open a new rule file, and put this under the line with version:
attr Land_Type = ""   # This will connect to your object attribute from the GDB.
Shape --> # This is the start of a rule.
     color(getColorByLandUse(Land_Type) # This calls the function below using your attribute.
# Expand this function using your land types, with colors in "hex color" format:
getColorByLandUse(landType) =
     case landType == "Residential" : "#ff00ff"
     case landType == "Office" : "#0000ff"
     else: "#000000"
RushikeshPadsala
Hi Chris Wilkins
That is really helpful. I have got two more queries if you could help me out.
1. I have a attribute field of Building Heights (Bldg_Ht) and I want to colorize it using color ramp. Is it possible in City Engine. Can you help me with an example of a rule with any random color ramp.
2. Is it possible to have a legend or any such alternative by which the person viewing this 3D scene will be able to know that this color belongs to what??? (Eg. if Residential are colored as red, then in legends, I should have a box with red color and a text saying as Residential).
Again please note that I dont have to extrude any building or any objects as I am importing everything in Multipatch 3D (LOD 2 Bldg Models) in GDB from ArcGIS.
Thank You 🙂
MatthiasBuehler
1] Yes, you can colorize with ramps in CGA. See here:
colorRamp
2] Legends:
Legends are not directly possible in CGA.
But I have developed custom python scripts for ourselves and a client that do exactly that. If you're interested in such a service, let me know.
--> Garsdale Design Limited
Matt
Interested in CityEngine training or services? Contact me!
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
RushikeshPadsala
Hi Matthias Buehler
Thank You for your reply and help. Ya I would like to know about the python script or any other alternative as I am a student and would like to learn it so as to include in my small test project.
Do help me
Thanx
RushikeshPadsala
Now I have a raster urban heat island layer which I analysed in ArcScene and I have brought into City Engine. No without legends I cannot share it within my university as no one will understand which color means what. I need to create legends in city engine. Please help if there is any way out or any alternatives for this.
Urgent Help!!!!
Thanx
MatthiasBuehler
the easiest way to create a legend is just to create a picture in e.g. PhotoShop and place it in the scene, as a map layer of the type 'texture' (see docs).
Ok?
m.
Interested in CityEngine training or Services? Contact me!
Matthias Buehler
twitter: @MattB3D
RushikeshPadsala
Thank You for your quick reply, I could have done that if I had one layer, i have 7 layers each showing a different theme, for example one layer is showing building colorized by its building types, second one is showing building colorized by its year of construction and so on. I would like to have legends of all seven layers and to create it with photoshop and then put 7 more layers, wont solve the problem.
Need your views on this
Rushi
MatthiasBuehler
Well, there is just no default functionality for legends in CityEngine.
It seems you're best off creating one picture with all data of all seven layers.
To have it more dynamic, you need to dive into Python scripting. Sorry.
Matthias Buehler
twitter: @MattB3D
by Anonymous User
Not applicable
Can you not put the seven legends on the seven layers?
