cityengine color by attribute
1395
03-28-2018 09:48 AM
KathrynAngleton
Hi everyone,
In ArcGIS, I assigned hex values by municipality in a polygon shapefile. I brought that poly file into CityEngine to extrude it based off a different attribute, and color it based off the municipality. I have 10 municipalities with their own colors, and the rest I colored white (#ffffff). As you can see in the screengrab, the rule I wrote is pointing to the correct attribute, however, it's not displaying the colors how they're supposed to. Any ideas on what's wrong with my rule file?
Kathryn
LR
Pu the coloring above the volume. Also the dot behind volume terminates the rule, so everything after that gets ignored.
