CityEngine 2013 initialization failed
4423
03-05-2014 11:16 PM
CristianoPedersini
I just installed the 2013 version of CityEngine. I tried it on two different MacOSX machines and on a Windows one, but I always get the same problem.
On startup I get a "Fatal Error":
"Procedural runtime initialization failed. See Log for details."
I have no clue what this is . Anyone can help me out?
When I go to the Log these are the details I get:
Message:
PRT initialization failed. PRT locations searched: bundleentry://15.fwk1281234799/lib/prt_extensions;file:/Applications/CityEngine2013.app/Contents/Resources/plugins/com.esri.prt.clients.ce.cocoa.macosx.x86_64_1.0.0/lib/prt_extensions;file:/Applications/CityEngine2013.app/Contents/Resources/plugins/com.esri.prt.clients.ce.cocoa.macosx.x86_64_1.0.0/lib/prt_extensions;/Applications/CityEngine2013.app/Contents/Resources/plugins/com.esri.prt.clients.ce.cocoa.macosx.x86_64_1.0.0/lib; - [main]
Exception stack trace:
com.esri.prt.clients.ce.CEClientException: No license
at com.esri.prt.clients.ce.CEClient.check(Unknown Source)
at com.esri.prt.clients.ce.CEClient.init(Unknown Source)
at com.esri.prt.clients.ce.CEClient.<clinit>(Unknown Source)
at com.procedural.cityengine.ApplicationCommon.start(Unknown Source)
at com.procedural.cityengine.release.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Session data:
eclipse.buildId=unknown
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments:  -keyring /Users/cristianopedersini/.ce_keyring -showlocation
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -data @noDefault -keyring /Users/cristianopedersini/.ce_keyring -showlocation
AndreaRoskelley
Were you able to resolve this issue? I am experiencing the same thing.
Andrea Roskelley
MichaelVolz
Esteemed Contributor
Are you installing the software on a 64-bit OS?
MatthiasBuehler1
Hi!
This issue was resolved with the CityEngine 2013 Service Release. Download the new installer.
Ok ?
Matt
