Batch import terrain layers?
1891
09-02-2019 09:43 PM
AndrewCampbell2
Is there any terrain importing functionality offered by the CityEngine Python API?
I can import both the heightmap and texture .tif files separately using the ce.importFile() method but I need to automate the process for batch imports so that each heightmap tile is draped with its respective texture file. Has anyone come across this problem?
Thanks
AndrewCampbell2
I made a solution. I missed that addAttributeLayer could perform the function. Here's a script if anyone wants to run a similar batch process. I found this necessary as my terrain files needed to be broken down to a smaller resolution.
Here, I have both the texture tiles and heightmap tiles named to match and located in sub directories.
from scripting import *
import os
# get a CityEngine instance
ce = CE()
# function to access the filename of a requested heightmap (.tif)
def get_heightmap(file):
   return 'maps/<sub_directory>/' + file
# function to access the filename of a requested texture (.tif)
def get_texture(file):
def main():
   # get a list containing all texture files (imagery)
   texture = os.listdir(ce.toFSPath('maps/imagery_by_grid_blocks'))
   # get a list of all heightmap files
   heightmaps_all = os.listdir(ce.toFSPath('maps/dem_by_grid_blocks'))
   heightmaps = [file for file in heightmaps_all if file.split('.')[1] == 'tif']
   # for each image in the texture list
   for image in range(len(texture)):
      t = get_texture(texture[image]) # get the texture image
      file_name = texture[image].split('.')[0] # this becomes the file name
         # loop through heightmaps to find the respective file
         for heightmap in range(len(heightmaps)):
            #find matching heightmap and texture file
            if texture[image].split('.')[0] == heightmaps[heightmap].split('.')[0]:
               h = get_heightmap(heightmaps[heightmap])
               ce.addAttributeLayer(file_name, t, h, True)
               print (file_name + ' has been added.')
if __name__ == '__main__':
main()
AndrewCampbell2
import os
ce = CE()
def main():
main()
leehwichan
import os
ce = CE()
return 'maps/dem' + file
return 'maps/texture' + file
def main():
main()
I wrote the script as above and I get the same error as in the last picture. I want to know the reason.
