Solved! Go to Solution.
I'm using CityEngine 2013.1 and holes aren't quite working for me either.
I'm importing parcels with the building footprints cut out. For some parcels it works fine (a 'hole' polygon and a surrounding good polygon), but sometimes it doesn't - it creates a hole polygon but the surrounding polygon doesn't have the hole cut out.
The screenshot attached should help explain. The proper polygons are selected and some have vertices around the hole showing the excluded empty area, but others unfortunately include the empty area.
It tends to be that the inner holes are excluded if they touch a boundary, but not if they are entirely within the larger polygon.
Nate
To clarify: holes are supported with following input formats:
??? CityEngine 2013.1: gdb
??? CityEngine 2014.0: gdb, shp
So if you import footprints with holes into CityEngine 2013.1 we recommend to use the gdb format.
Hi Matt,
Using .gdb did the trick, thanks 🙂
On a related note, I'm having trouble with setback operations on the imported parcels (which have holes from the buildings being cut out). As a simplified example, I've attached a screenshot of the following operation:
Lot -->
Testing1 Testing2
Testing1 -->
color(0,1,0)
extrude(6)
Testing2 -->
setback(3){world.east : NIL | remainder : Testing3}
Testing3 -->
color(1,0,0)
extrude(5)
When I do this, many results (Testing3) fill the hole in as part of the remainder. This is shown in the left parcel of the screenshot, where the red portion is a hole in the original parcel and shouldn't be included in the result.
The parcel on the right has the same rule applied but correctly still excludes the hole.
I'm not sure if this is a remaining issue with holes in imported shapes, or just something with the setback operation.
Is there a way to spatially limit a result to the original shape, so that a result doesn't spill over the boundaries?
Thanks
Nathan
