Adjusting Street Widths After Shapefile Import
4031
06-02-2015 08:39 AM
Stephanie_Dockstader
Hi There-
I have a roads layer that I imported as a shapefile into CE.  I was able to assign the street width value using the attributes in the file and generate road models.   However, my scene is in meters and the road width are listed as decimeters.  I would like to keep the overall scene units in meters.  Is it possible to read the attribute from the shapefile, apply a multiplier, and then push it back into the streetwidth parameter?
Thanks!
--SC
SepheFox
Hi Stephanie, you can add a field to your shapefile, and then calculate the field as = decimeters_field*0.1. I'm not sure if you'll have to re-import your shapefile into CE after that.
SepheFox
