comp(e){convex:x|concave:y}
2606
09-25-2022 09:02 AM
romainjanil
jus thinking about how handy it would be right now (:)) (like a more generic version of ridge/hip/etc selectors), and probably already asked for it many years ago 🙂 (would be off course determined by parent faces normals hence for manifold shared edges only( border edges, flat or non manifold would be skipped)?)
3 Comments
CherylLau
Interesting idea.  Do you have a specific use case in mind?
romainjanil
tons of,
first is comp(e) from for shapes coming from envelop() which are not regular roofing operation hence do not really support hip/ridge/valley etc selectors (everything falls in ridge)
2- for more easy identification (and further derivation) of corners between faces (ie from a concave A rectified shape to insert instanced rounding:
A-->extrude(3) comp(f){side=B C}
B-->comp(e){concave:ConcCorners|convex:ConvCorners}
ConvCorners-->i(assetForCorner("conv"))
ConcCorners-->i(assetForCorner("conc"))
3, insert some proxy labeled shapes going to NIL against which other part of a facade could test so to get smarter generic adaptative facade patterns (avoid balconies in corners, or the contrary etc)
many many use cases I think and ti's very generic.
Best
Romain
ChristianIten
