Cga window zoom problem
4331
9
06-18-2022 08:44 PM
Status: Implemented
zizicocata
Hi
I use  3840  * 2400 monitor
If i write in cga window
Font is very small
Inwould like yo suggest zoom window
Tags (1)
9 Comments
Chris_ce_team
Hi
we are currently not planning to offer font size settings in the CGA and/or python editor(please let us know in case you have something different in mind with "zoom window". We assume that that the scale factors in display settings on OS level offer sufficient control for most of our user base.
JeoCho
Can you know notpad app
That can  zoom as  my ease
ChristianIten
I assume you are using a scaling factor of 100% and you suggest larger fonts for the CGA editor only?
Note that with CityEngine 2022.0 the CGA editor can be detached and used on a secondary monitor.
JeoCho
Yes yes right
I would like to adjust font size
ChristianIten
ElliotHartley
You can change the font size though unless I misunderstood the question.  I do it all the time for when conducting training sessions!  Right-click on CGA editor window and select 'Preferences', then in dialog box click on the 'Colors and fonts' text at the bottom. In the Colors and Fonts settings click on the list text that says 'Text font' and then on the top-right of this dialog click edit, here you can change font  (great for when you can't tell between 1 and l) as well as size. Then click Apply and Close..
What would be good though is to not have to jump through so many dialogs...
JeoCho
Thank you for good advice
Mabey
That feature seems to only exsit in the new version
ChristianIten
ChristianIten
Thanks  ElliotHartley, I wasn't aware of this!
