Block boundary
3234
7
09-28-2021 03:20 AM
Status: Open
MatoBaloga
Would it be possible to add BLOCK BOUNDARY. Not all blocks are surrounded by streets (graph network), but are at the edge of the city. The boundary could enclose the block polygon idependent od graph.
Blocks could by divided by the boundary.b
7 Comments
by Anonymous User
I like your idea!  I think a "boundary line" that doesn't effect the street network geometry, particularly  by not creating a new node shape, would be great.
Just wanted to note, sometimes you can work around this by creating a street with 0 width and 0 sidewalk widths to help enclose a block without modifying the street shape.   But you might have to tinker with how it interacts with your street shapes because it will likely effect the street node's geometry negatively or undesirably.
MatoBaloga
Thank you, @Anonymous User  The main  idea was exactly not to affect street network. Zero-street works, but addes new nodes to street geometry (at least).
ChristianIten
Yes, the workaround atm is to set street and sidewalk width to zero.
Can you explain more where you run into issues with this approach?
MatoBaloga
Zero lane width is not possible to set and there is always issue with the graph network.
The block should have a boundary that does not consist of streets, because is at the end/edge of the city.
ThomasFuchs
Hello @MatoBaloga
Thanks so much for sharing your thoughts! I just wanted to mention that with the new CityEngine Street Designer, you can now achieve a 'zero lane width' by simply removing the lane:
Remove lanes—ArcGIS CityEngine Resources | Documentation
Hopefully, this helps address the issue you mentioned.
MatoBaloga
Yes, but the 0 lane interact with other streets.
ThomasFuchs
Status changed to: Open
Thanks for the clarification. You are pointing out, that the necessary creation of the connecting node to the street network, does influence the initial shapes for the model generation. In the example below, the result is an altered lantern placement.
