Loading already defined unique geographies for use in Business Analyst
1291
05-07-2021 11:14 AM
NeilPennanen1
I would like to be able to use a number of geographies already defined by my organization to carry out analysis. The process I'm looking for would follow a similar pattern within Define Area as the the Draw Polygon tool. I have 20 polygons I'd like to look at in Business Analyst but can't figure out how to carry out this analysis without having to draw them again in the BA web interface.
Is there a way to import my own polygons to use as the Defined Areas in which I'd like to carry out the analysis?
FasilTiru
Hello @NeilPennanen1 ,
I believe you are looking for this workflow: https://doc.arcgis.com/en/business-analyst/web/import-file.htm#ESRI_SECTION1_3B6A81133D004B00B3CA35F...
Please note that once you import your geographies, you can always access them from your project table here:
Cheers,
Fasil
BA Team
FasilTiru
Cheers,
Fasil
BA Team
