Infographic template theme customisations
648
07-07-2025 02:26 AM
BillSands
Hi All,
I'm playing with the custom infographic template themes, and have mostly worked out how the themes work, but I have a rather irritating problem with my charts. If I customise the charts so that there are faint lines behind the chart, using the "Grid lines and stripes" section, transparency, set to 90%, and then set a template theme, the Grid lines and stripes setting is un-done.
How do I set that setting in the template theme?
Any help is much appreciated.
Bill
LinweiZeng
Hi Bill,
Thanks for bringing this up! I tried to reproduce the issue on my end by setting the grid lines and stripes, then switching to a different template theme. In my case, the theme changed as expected, but the grid line settings remained intact.
If you’re still seeing the issue, feel free to share more details or screenshots — we’d be happy to take a closer look.
Cheers,
Linwei
