How to add a variable containing text
1289
04-05-2023 11:48 PM
JessicaHancock
PLEASE HELP! My table contains four fields, each with a custom text value associated with the record (in this case, each record is a census tract). I need to place these values in my infographic but can't figure out how to make them show up on the report. The only variable types I see are for values that can be calculated. Is there a way to insert a value that won't be calculated and is for information only? Thank you!
FasilTiru
Hello @JessicaHancock ,
You can add string values from your layer using the "Map Layer" option when building infographic.
Please see the 2. Map Layers section of this blog: https://community.esri.com/t5/arcgis-business-analyst-blog/best-practices-when-sharing-and-running/b...
Fasil T.
FasilTiru
Fasil T.
