BA Dashboard layer actions with infographic
1248
07-01-2024 01:25 PM
Tali23
Hello,
I have created a dashboard through business analyst, by sharing sites for an infographic. The dashboard that was generated has a dashboard, a map, and a list, and I am trying to configure it so that a user could click on a site name on the list OR on the map, and both methods would generate the infographic for that site.
However, it seems I can only have one method work at a time, and when I try to configure the second method, it renders the first method unusable, showing a "no data" message where the infographic should be. I first configured the map, and it worked, and then configured the list, but now only the list generates the infographic and nothing happens when I click on a site from the map.
Here are the configurations I have, please let me know if I should change anything so that both the list and map connect to the infographic. Thanks!
FasilTiru
@Tali23
I was able to get both the map and list actions update the infographic (embedded content) by configuring the map settings as follows:
However, the list will also get filtered this way and you will have to clear the map selection to get the full list back.
My recommendation is to post this question under ArcGIS Dashboard page as it seems a limitation of the dashboard app:  https://community.esri.com/t5/arcgis-dashboards-questions/bd-p/arcgis-dashboards-questions
Fasil T.
Tali23
Thank you for your help! I will post on the Dashboard page
