How to add scales to the maps of the classic reports of Business Analyst?
Hi Daniel,
Are you asking about the Site Map report?
Best regards,
Donna
Hi, Donna, yes, when adding a map element, it doesn't bring a legend or scale. The legend can be solved by adding an image, but I haven't come up with any idea for the scale.
Hello Daniel,
The Site Map report should include the map scale, however, there currently seems to be an issue where the map scale is being mostly cutoff. The map scale should appear in the lower left corner of the map and it is now only partially shown.
Thank you for reporting this issue. We will work to resolve the problem as soon as possible. As a temporary work-around, you might try adding the site to the map and creating a PDF. The PDF includes the map scale.
We greatly appreciate your feedback and thank you for using Business Analyst!
Best regards,
Donna
