Accessing Data by 6-Digit NAICS Codes
1159
10-28-2025 08:33 AM
JessieC
Hello! I’m on the BA web app and need some help locating retail expenditure and demand data at the 6-digit NAICS level.
Currently, the built-in “Retail Goods and Services Expenditure” report doesn’t include any NAICS codes, and the “Retail Demand by Industry” report only provides 3- or 4-digit codes, which are too broad for my analysis.
I have also tried customizing the reports and exploring the POI search in the “Create Maps” tab. While it allows you to search by NAICS code, it doesn’t link to any data on retail consumer expenditure or retail demand, so I’m a bit stuck.
Is there a way to access or generate data from the “Retail Goods and Services Expenditure” and “Retail Demand by Industry” reports at the 6-digit NAICS code level?
Any guidance would be appreciated!
Priya_Das
Hi @JessieC
You can refer to this document "SafeGraph NAICS codes update in ArcGIS Business Analyst":https://www.esri.com/arcgis-blog/products/bus-analyst/announcements/safegraph-naics-codes-update-in-...
LinweiZeng
Hi @JessieC, Happy New Year!
Currently, the data isn’t available at the level of granularity you’re looking for. However, we’ll document your request and explore the possibility of developing something similar in the future.
The POIs search is designed to identify businesses and points of interest within your analysis area, so it may not be the right tool for this specific research goal.
Would you be open to a conversation about your use cases?
