The whole point of having a mobile version of the app, and a mobile version of the entire project, is so that all layers are available on the mobile version. As there is already “Define areas” option, an alternative would be for the data I’m adding via the "Add Data” option would, by default, be added to the Pont Locations (sites). Instead of “My point locations” it could be named “Site point locations.” You can’t expect me to add 100, or 500, or 1,000 or more addresses one at a time just so that I can have a copy of the entire project on my phone! Thank you.
Jim Wooten
Hi Jim, thank you for your feedback. Regarding the "Add Data" option in BA Web App, when you use Import File workflow within it, and add points, at the end you have the option to just save it as a layer, or to create sites from them by applying buffers (eg rings, drive times).
