Hi - if you are editing in Pro, you may need to click the 'Finish' button.
Hi David
How can make obstructionldSurface_MP in Aacgis Aviation can you help with one example
Hi Altin,
I have previously posted a video to create the aviation Airports geodatabase. Using this tool will create the ObstructionIdSurface_MP feature class inside the Airspace feature dataset.
Once you have that Airports geodatabase, you can populate the RunwayCenterline feature class and then use the ICAO Annex 14 tool to create the surfaces. There is a video on that here:
These should help
David
Hi David
Thnx for your email this video are for arcgis pro 2.6 but I have in my compiuter arcgis pro 2.2.0 version I need your help or I can send the point of runway for finish this OLS for i can send the figure version of arcgis pro 2.2.0
Hi David
I need your help I have done OLS Annex 15 and I need your opinon ... for this ..
I have the problem with tab 1 for more attach file ...{ I thing I ought write runway 18/36 and everythis is ok for this ?}
Hi Altin,
You are correct to set your runway as '18/36', to avoid seeing this warning.
The OIS tools do expect to have an input runway centerline input feature with a designator field, (such as: RWYDESG | RUNWAYDESIGNATORIDENTIFIER | DESIGNATOR_TXT), which should be populated in this format: 09/27, to ensure compatibility with Aviation Analysis tools. For more info see this PDF linked under the Usage in the help for each OIS tool.
