Analyze Runway Obstacles output - OIS Dataset
230
07-17-2025 07:42 AM
JasonWeis_Westwood
When using the Analyze Runway Obstacles tool to perform an obstruction analysis, the resulting table only references the OIS surface for each row in the OISDataset field with the format:
ObstructionIdSurface_MP OID:145
For airports with multiple runways, multiple status (existing vs future), etc., this makes it difficult to review and interpret the results, since obstruction points often have multiple returns - one for each intersecting surface. Currently, we need to strip out the text up to and including the colon, and join to the OIS_MP feature class based on the remaining OID to obtain the relevant surface information and allow for review and possible filtering.
To make it more useful, please consider either:
(a) Separating the OISDataset field into two fields, one for the dataset name (OISDataset) and one for the OIS ID (OID) to simplify the joining process; or
(b) Carrying additional fields from the OIS Dataset over to the results table for each surface record, including:
  • OBJECTID (OID)
  • Status
  • Runway Designator
  • OIS Surface Type, Description, and/or Name
Of these two, (b) would be preferable, since it would eliminate the extra join step.
1 Comment
KiyoshiYamashita
Thanks for this suggestion.  I've added this feature to our road map for consideration.
