Arcade script to add unique value for duplicate field entries
1723
9
03-12-2026 07:14 AM
Labels (2)
JustinBernard1886
Hi everyone,
I am casual user of arcade scripting and I wonder if anyone can help me with some script?
I have a simple script where when someone enters a value into a field, the script will populate another field with "1" at the end.
What I need help with is when someone enters the same value again, I would like the duplicate value to have a "2" and increase for every subsequent duplicate value.
Here is the script that I wrote initially.
var FieldName = $feature.StopID_text;
return Concatenate ($feature.StopID_text + "-" + "BB" + "-" + "1") ;
Thanks for the help!
Cheers,
Justin
KenBuja
My apologies. I forgot to add a wildcard in the sqlExpression. Here's the tested code that works
var fs = FeatureSetByName($datastore, "GIS_Miway_LandingPad");
var string = `${$feature.StopID_text}-LP-`
var sql = `${string}%`;
var filtered = Filter(fs, "AssetID LIKE @sql");
if (Count(filtered) == 0) return `${string}1`;
var list = [];
for (var f in filtered) {
  Push(list, f["AssetID"]);
function reverseSort(a, b) {
  if (a < b) return 1;
  if (a > b) return -1;
  return 0;
var highest = Sort(list, reverseSort)[0]
return `${string}${Number(Split(highest, "-LP-")[1]) + 1}`
In my test data, I used the Habitat field
AlfredBaldenweck
MVP Frequent Contributor
Basically you need to get a list of everything already in Field2.
Fair warning, this is my second time on this. The first time I crashed Pro when I added a new record and had to rewrite. Idk why but the rewritten version seems to work just fine.
// Get list of all the current values in Field
var self = FeatureSetByName($datastore, "test")
var field2List = []
for (var s in self){
    Push(field2List, s["Field2"])
// Create a counter and your output string
var counter = 1
var out = Concatenate($feature.Field1, "-BB-", counter)
// Be careful with the while loops.
// Had to nuke Pro twice because I got stuck forever while writing this.
// No getting stuck on deployment, though
while (Includes(field2List, out)){
    // Update counter and the output so you can escape the loop.
    counter+=1
// Return the output
return out
KenBuja
I was looking at it another way, incrementing the counter for the unique values of `${$feature.Field1}-BB-`
I haven't tested it, but was thinking along these lines
var fs = FeatureSetByName($datastore, "yourLayer");
var sql = `${$feature.Field1}-BB-`;
var filtered = Filter(fs, "Field2 LIKE @sql");
if (Count(filtered) == 0) return `${$feature.Field1}-BB-1`;
var list = [];
  Push(list, f["Field2"]);
  return 0;
return `${$feature.Field1}-BB-${Number(Split(highest, "-BB-")[1])+ 1}`
In line 3, the FeatureSet is filtered to only show the existing values for that field. If there aren't any, it returns the string with the counter = 1 in line 4.
Lines 6-9 create a list of the values in Field2. Lines 11-15 are a reverse sorting function (taken from the Sort example) to get the highest value in line 17. Line 18 returns the string and the highest value incremented by one.
AlfredBaldenweck
I'd be interested in finding out how our two methods compare, performance-wise. I think yours may scale better?
JustinBernard1886
Thanks so much guys!
I'll try both out and let you know how it goes.
JustinBernard1886
All right,
I;m trying the second code, and I am getting a "invalid where clause." on Line 4.
Here is the code:
var sql = `${$feature.StopID_text}-LP-`;
var filtered = Filter(fs, "LIKE AssetID @sql");
if (Count(filtered) == 0) return `${$feature.StopID_text}-LP-1`;
var list = [];
return 0;
return `${$feature.StopID_text}-LP-${Number(Split(highest, "-LP-")[1])+ 1}`
Justin
KenBuja
When posting code, use the "Insert/Edit code sample" button.
The syntax is incorrect on the Filter's sqlExpression
JustinBernard1886
Ahhh.
Thanks.
The code almost works. The field populates but returns a duplicate value.
var filtered = Filter(fs, " AssetID LIKE @sql");
var list = [];
  return 0;
KenBuja
var list = [];
  return 0;
JustinBernard1886
That works!
Thank you so much Ken! ❤️
